Since the AMG8831 comes in a package similar to DFN (Dual Flat No-leads) packages, a breakout board was necessary. An additional requirement for the breakout board was that it would be usable in a prototype of the module, requiring a small footprint.
Eagle was used to design a breakout board and a bunch of them were ordered at DirtyPCB, because I'm cheap.
Since the AMG88xx data sheet recommends reflow soldering, I used a reflow oven for the first time in my life and found out the thermocoupler was broken, luckily without the AMG88xx attached.
Using a different reflow oven, it worked. In the end the AMG88xx was attached with hand soldering (using the instructions in the data sheet) as the reflow oven could not manage to comply with the strict reflow profile from the data sheet.
