The print head assembly is a customized version of the Wim3rl.
The designer (Mathias Dragobert) describes the Wim3rl:"This head is an all-in-one solution, where the cooler and hotends are one stiff, durable and heat-resistant package. The head weights only 80 g (not including heaters and connectors to tubes and hoses) when filled with water, being as heavy as a common plastic part with the hotend and cooling components.”
https://www.kickstarter.com/projects/1057128232/wim3rl-water-cooled-print-head-with-3-nozzles-for
Despite an unsuccessful kickstarter campaign Mathias was extremely helpful and produced this customized version for me adapted to the magnetic push rod ball ends.
Looking up:
