Hackaday.io Hackaday.io
Sign up Log in
LIN IT!
Aim of LIN IT! project is to prepare a system for developing cheap and LIN(Local interconnect network) complaint devices, for ROS.
lukasz-juranekLukasz-Juranek
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
1k views
0 comments
7 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 5
    • View all
  • Instructions 0
  • Discussion 0
  • The 2018 Hackaday Prize
View Gallery
Public Chat
1k
0
7
3
Team (1)
  • lukasz-juranekLukasz-Juranek
Join this project's team
  • source
  • project page
  • Open LIN
  • Tutorial on LIN
MISC
ongoing project
automotive lin ROBOT 2018hackadayprize Local interconnect network
Related lists
2018 THP: Digikey Parts
Hackaday Prize entries using Digikey parts
This project is submitted for
  • Robotics Module Challenge
This project was created on 04/24/2018 and last updated 8 years ago.
Description
Prerequisites:
1. All is open source
2. I'll trying to make hardware as cheap as possible.
3. In the end system needs to be able to communicate with any linux OS computer
What is done:
1. Cheap USB LIN Converter production started, device tested with JAVA client, tutorial ready
2. Hardware for example LIN Slaves done (LIN Motor driver, LIN magnetic sensor, LIN relay)
3. Basic Open source plain C LIN Library
Steps to be made:
1. Test USB LIN Converter test with SLCAN, and prepare tutorials
2. Write some software to map LIN signals from SLCAN to ROS signals, and prepare tutorials
3. Make embedded software for SLAVES
4. Test whole system, and make robot designers live easier.
To see what is LIN network see tutorial in links, shortly i'll post next movie on the concept of LIN IT!
Project Logs
Collapse
  • LIN JSON parser
    Lukasz-Juranek • 06/01/2018 at 08:03 • 0 comments
    Pars JSON request to slcan data with node js and  https://github.com/ucandevices/ucan_json_parser
  • Check open LIN implementation for Your projects
    Lukasz-Juranek • 06/01/2018 at 07:30 • 0 comments
    Open LIN implementation on Github https://github.com/open-LIN/open-LIN-c
  • LIN motor driver board
    Lukasz-Juranek • 06/01/2018 at 07:29 • 0 comments
    First draft of LIN motor driver board + embedded code on GitHub https://github.com/uCAN-LIN/LINDCMotorDriver
  • LIN-relay
    Lukasz-Juranek • 06/01/2018 at 07:26 • 0 comments
    First release of LIN relay board is almost ready. Board and embedded code to be checked here  https://github.com/uCAN-LIN/LINRelay
  • LIN with Socket CAN on Linux
    Lukasz-Juranek • 04/25/2018 at 16:43 • 0 comments
View all 5 project logs
Log In/Sign up to comment
Sign up with Github
OR
Three axis stepmotor driver, limit switch conditioning and power supplies.
Project Owner Contributor
Stepmotor Driver Board for TI Tiva Launchpad
bharbourBharbour
The 2017 Hackaday Prize
Build cool things with M10. For starters, you can build a Lego Monster Truck with it. For more fun, how about home automation through DTMF?
Play FPGA like Arduino
changyi-guChangyi Gu
The OpenCTD is a low-cost, open-source oceanographic instrument. This calling card helps you build your OpenCTD by providing a test bench.
A calling card for oceanographers
andrewdavidthalerandrew.david.thaler
Supplyframe DesignLab: 2022 Hackada…
Achieve better than 0.1° sun tracking accuracy with a compass a tilt sensor and a shading beam sun sensor.
Open Concentrating PV Solar Tracker Controller
ruediger-f-loeckenhoffRuediger F. Loeckenhoff
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "LIN IT!", please tell us the reason.
Send message
Remove Member
