The next stage of the project is to use a Raspberry to drive the 6 Arduino's. I plan to use the output of Glediator as the input files. I am able to see the /dev/ttyUSB0 through /dev/ttyUSB5 devices. I'm trying to write a C++ program on the Raspberry Pi to send the data. I know I'm sending data as I see the Rx/Tx lights. But the Arduino does not always do what I expect it to do.
I'm still trying to get this to work. At this point I'm trying to get communications going that I can trust.
This is the C++ code I'm running on the Raspberry Pi. I'm leaving the communications rate at 9600 baud. I have also I have also used: stty -F /dev/ttyACM0 sane.
I have tried other settings. I have tried code C code as well.
I'm using an Arduino Uno for this test. That is why it use the /dev/ttyACM0 instead of the /dev/ttyUSB0
#include <iostream>
#include <fstream> using namespace std; Int main() { ofstream USB; USB.open("/dev/ttyACM0"); USB << "asdfasdf"; USB.close(); return 0; }
If I use the Arduino serial monitor, it works exactly as expected. 1 second of LED on per character sent. Also prints the character in the serial monitor. If I run the C++ script, is see the Rx/Tx light go, but usually does not cause the LED to lite for 8 seconds. If I run it several times, one might work. I'm thinking that must have something to do with serial flow control.
Does anyone have any ideas?
Also, I don't have remote access setup on my Pi yet, so I copied the code by hand. Please excuse if I made a typo.
This is the Arduino code I use with Jinx! using the Glediator protocol:
It has one problem. I had to put an extra while(serialGlediator() != 1) {} at the bottom that I just throw away. Otherwise there random patterns that flash. Still trying to understand why. But it works!
// Glediator script for WS2812B LEDs // Found at: https://forum.pjrc.com/threads/32861-Glediator-Jinx-with-Teensy-3-2-and-WS2812b // User mortonkopf 02-09-2016 @ 4:57 PM // Tested with JINX! // Set NUM_LEDS to the number of LEDS in the string your are controlling. // Set dataline to the Arduino PIN you are going to use. // You must install the FastLED Library. // I have tested wint Arduino UNO R2 and R3. Arduino Mega 2560 R3 and SainSmart (Not sure which version) #include "FastLED.h" #define NUM_LEDS 300 // Set the number of LEDs const int dataline = 6; // Arduino PIN CRGB leds[NUM_LEDS]; void setup() { Serial.begin(115200); LEDS.addLeds<WS2812B, dataline>(leds, NUM_LEDS); } int serialGlediator() { while(!Serial.available()) {} return Serial.read(); } void loop() { while(serialGlediator() != 1) {} for(int i=0; i < NUM_LEDS; i++) { leds[i].r = serialGlediator(); leds[i].g = serialGlediator(); leds[i].b = serialGlediator(); } FastSPI_LED.show(); while(serialGlediator() != 1) {} //delay(100); }
#include <iostream>
#include <fstream>
Int main() {
ofstream USB;
USB << "asdfasdf";
USB.close();
return 0;
This is my test script on the Arduino
char inChar = -1;
void setup() {
Serial.begin(9600);
pinMode(LED_BUILTIN, OUTPUT);
void loop() {
while(true) {
while(serial.available() > 0) {
inChar = Serial.read();
digitalWrite(LED_BUILTIN, HIGH);
delay(1000);
digitalWrite(LED_BUILTIN, LOW);
Serial.write(inChar);
