For my proto, I am planning to go as 'off the shelf' as possible. A lot of my other designs have a lot of 3D printed parts, but this frame is going PVC...
PVC::
1 inch PVC pipe is awesome. Just, awesome. Things I have built with it include:
- hammock
- greenhouse
- fan stand
- hot-wire foam cutter
- and i have actually used it to carry water (weird, I know)
Gimbal::
Rather than try to build my own gimbal and gimbal controller, I am opting for a pre-made consumer gimbal (boo, hiss, DIY faux pas...) It comes with motors for under 60$CAD.
Battery::
Custom building lipos from separate cells is retarded. And zappy-smokey sometimes. Oops. OTS please. 3s 1300mah should be plenty for hours of entertainment.
Microcontroller::
Arduino Nano cause I have a pile of them. Proto will be hardwired to a Tx for control. Bluetooth/WiFi may be added later via Pi Zero W. Softwares will be fairly stock too.
Phone::
I know, I know... iPhone? Am I serious? Maybe. Mostly it is an easily found model... Not for me personally, but to each their own.
