Having looked at hundreds of gimbals, I am going for cheap, light and simple. Essentially all versions of this are all very similar.
To attach it, I will flatten a section of PVC pipe ( the piece that goes between the grips) drill and bolt in place.
The gyro unit that resides on the camera base may need to be re-oriented so that the phone/tablet can be attached to the (former) bottom of the gimbal frame. Pics will follow...
ken.do
That will be solid ;-)
