The backplane will then be bolted against the door. Out of the aluminum profiles I buildt a linear guide which allows to move a small plywood plate of approx 10 by 10 cm up and down.
On that plate sits the front plane wich holds the hook for the rollator.
You maybe notice the blue end switch. There is one switch for up and one for down position.
