AppleMIDI and Open Sound Control (OSC) protocol requires a network connection. Pedalino support IEEE 802.11 b/g/n Wi-Fi with WPA/WPA2 authentication (only 2.4 GHz).
Pedalino implements Smart Config technology via Espressif’s ESP-TOUCH protocol to help users connect embedded devices to a Wi-Fi network through simple configuration on a smartphone.
Tested apps for configure SSID and password are:
- ESP8266 SmartConfig for Android
- SmartConfig for iOS
Boot procedure
- On power on Pedalino will try to connect to the last know access point (double blinking led)
- If it cannot connect to the last used access point within 15 seconds it enters into Smart Config mode (slow blinking led)
- Start one of the tested apps to configure SSID and password
- If it doesn't receive any SSID and password during the next 30 seconds it switch to AP mode (led off)
- In AP mode Pedalino create a WiFi network called 'Pedalino' waiting connection from clients. No password required. Led is off until a client connect to AP.
- Led is on when Pedalino is connected to an AP or a client is connected to Pedalino AP.
- Led will start fast blinking when Pedalino is partecipating to an AppleMIDI session.
- Reboot Pedalino to restart the procedure.
You can reset the last know access point via menu.
alf45tar
