Parts arrived sooner than expected! I also got more filament from Diamond Age Solutions so now I can continue.
Iteration 5 of the pulley belt clamp, I'm only printing a fraction of the pulley to save on printing while I test what works best. I'm satisfied with it. It holds the belt very tight, is robust and easy to print and adjust.
The upperarms also went through a few iterations and I printed a couple. I'll get some pictures up when I get a complete set.
As with all my project files for the Icepick Delta, they can be found on the github repository.
Any questions or suggestions, please do ask!
TTN
