Hi, we finally printed out and made it work as you can see on the next video.
The build instructions are pretty self explanatory, however in the video we skip the servo dismouting part and glueing the gear to the potenciometer, let us know if you need a video of that also.
About the humidity, this was the solution:
A big box with lots of silica in it.
