Hi!
it has been a long time o there is a lot to tell you about.
First, we made the ¨hall sensor 3d printed mini linear actuator¨ working. It works great and it much much easier to print and assemble that the previous one, less pieces, ligther and cheaper. So we will publish the files in due time or if anyone specifies a request.
Also, we were at the WMF at New York and it was awesome!
We met with:
Curt https://hackaday.io/project/159098-stomach-acid-powered-smart-pill
Kent https://hackaday.io/project/94611-gutters-to-gardens
Johannes https://hackaday.io/project/120377-3d-printed-strain-wave-gear
and Michael https://hackaday.io/project/20165-linear-delta-robot-3d-printed
All of them had great porject and most importantly willingness to contribute and share so check them out and drop a like.
We had the opportunity to be a part of a live tweet in hackaday so check that out also:
https://twitter.com/hackaday/status/1043532657437470720
Thank you everyone that took interest in this project, that got us to the semifinals and has made us learn a lot.
So as always feel fre to ask anything.
