Hackaday.io Hackaday.io
Sign up Log in
VALTALK V1
GSM based Relay control board using DTMF/MQTT with IVRS
raviypujarraviypujar
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
  • The 2018 Hackaday Prize
View Gallery
Public Chat
401
0
1
2
Team (1)
  • raviypujarraviypujar
Join this project's team
  • Designing a DTMF based Home automation system - GS
hardware
ongoing project
DTMF GSM 2018hackadayprize sim800c IVRS
Related lists
111
111
This project is submitted for
  • Robotics Module Challenge
This project was created on 04/26/2018 and last updated 8 years ago.
Description
It had been a long time since i wanted to make a building automation system. In fact it was the first product i ever dream’t of making. Time passed and i didn’t quite find the time and interest to venture into it as i felt that building automation is a old concept and there are too many players doing the same stuff.
So i designed this board, which can control the relays on board, based on the inputs provided either from cloud or from a call using DTMF.
Features :
For the first iteration we designed it to have the following features,
4 cube Relays driven by MOSFET’s to control 110V to 230V AC appliances
SIM800C 2G Quadband GSM module for cloud/call connectivity with micro SIM card connector
External Whip Antenna with right angle SMA connector
MP3 player with micro SD card
STM32 Cortex M0 Low power MCU with RTC
Switching power supply to take inputs from 5V to 24V DC
DC power jack for power input
SWD connector for programmi
Details
Log In/Sign up to comment
Sign up with Github
OR
A UPS modified such that power ports are individually controllable, via wireless RF network commands
Project Owner Contributor
Reactron energizer: Interruptible Power Supply
kenji-larsenKenji Larsen
This board is responsible for controlling the thrusters of our newest AUV.
Thruster Board
ufrj-nautilusUFRJ-Nautilus
This clock uses a single, very large Dalibor Farny Nixie tube to display the time.
Large Single Digit Nixie Clock
glen-akinsGlen Akins
The 2017 Hackaday Prize
Plugs into the fuse socket of mediocre switch boards, connects it to WiFi and monitors the power consumption of that room through smartphone
AutoFuse: Plug and Use Automation & power monitor
animesh-chattopadhyayAnimesh Chattopadhyay
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "VALTALK V1", please tell us the reason.
Send message
Remove Member
