FOund out mu calculations (basic trig were stuffed!)
Have rectified and did a scan of the cardboard box.
When plotted - I saw the outline of the cardboard box.
The lidars did return a few weird readings (outliers) - I believe I can set the lidars for long range or short range. Going forward will have to consider if the turrent would be used in robotics projects what is the range required - suggestions?
