Have 2 Pi's - one designated brains has a 2gb boot disk - holds Mysql database.
The other designated Turrent has SD as operating system. COnnects via I2c to various giblets and will connect via PWM to servo,
A project log for Robotics sensor - 360 scan of environment
A turrent which is an array of 4 lidar sensor's along with two compasses and a servo that scan the environment and dump data into database.
