Minor whoopsie - the compasses are on a fixed address - therefore both compasses will be connected to the I2c port expander and selected in turn.
(for some reason I thought you could add vin to one pin to change I2c address)
Anyway.................
A project log for Robotics sensor - 360 scan of environment
A turrent which is an array of 4 lidar sensor's along with two compasses and a servo that scan the environment and dump data into database.
