The one-time pad library was updated to extract an EncodingStrategy interface to make it easier to plugin in different encoding strategies. For instance plain Base16, Base16 with ECC, different characters for the hex code points, or even phonetic alphbaet encodings like "alpha, bravo, etc."
Scott Hasse
