Got the first rotor put together last night. Just waiting on pogo pins. I updated the Ringstellung so that it can accept a M3 set screw to hold it in place if the friction fit isn't adequate.
The letters are printed separately in a single strip. I print the white part and then swap to black filament then cut the letters from the thin backer and super glue them to the ring.
