Programming a PIC16F628 microcontroller using MPLABX and PICkit3 - A Hello World Program demonstrating the basic principles of writing a piece of ASM code. The LEDs on the PORTB are lighting up according to some pressed buttons on the PORTA used as an input here.
For details about the hardware used in this video, refer to the following website: www.funelectronicstoday.com
The result code, in case you want to copy-paste it:
; Hello world basic 16F628 ASM program
RESET CODE 0x00
#INCLUDE P16F628A.inc ; put angle brackets here
__CONFIG _HS_OSC & _CP_OFF & _LVP_OFF & _BODEN_OFF & _MCLRE_ON & _PWRTE_OFF & _WDT_OFF
; THIS PROGRAM WAS DESIGNED FOR 20 MHZ OSC
;_XT_OSC : EXTERNAL 4MHZ
;_HS_OSC : EXTERNAL 20MHZ
;_INTRC_OSC_NOCLKOUT : INTERNAL 4MHZ
CBLOCK 0X20 ; THIS IS HOW YOU DECLARE A BLOCK OF VARIABLES
NVAR1, NVAR2
ENDC
CLRF PORTA ;SET THESE PINS BEFORE YOU ACTUALLY CONFIGURE THEM
CLRF PORTB
MOVLW 0X07 ; DISABLE THE COMPARATORS AND ENABLING THE PINS FOR
MOVWF CMCON ; FUNCTIONING AS I-O
BCF STATUS, RP1 ;SETS BANK1
BSF STATUS, RP0 ;
MOVLW B'00111111' ;SET PINS 0 - 4 AS INPUTS ; TRIS 5 AS 1 ALWAYS
MOVWF TRISA
MOVLW 0X00 ;SET PINS 0 - 7 AS OUTPUTS
MOVWF TRISB
BCF STATUS, RP0 ;
;MAIN LOOP----------------
REPEAT
MOVFW PORTA
MOVWF NVAR1
MOVFW NVAR1
MOVWF PORTB
GOTO REPEAT ; END OF MAIN LOOP
END
Marius Taciuc
