Components
- 2x Linear rails
- 4x Linear Bearings
- wood and screws
- 11.1V 1500mAh Lipo Battery
- Analogue Current Meter 20A
- Digital Current / Voltage Meter
- Robot Leg
Assembly
The rectangular extrusion is the same size as the quad's "backbone" and the robot's hip joins with the following design.
The robots hip has three mounting points to the rectangular extrusion.
