Before Cycloidal Gearboxes, I research Concentric Magneti Gearboxes.
I made an improvement on the current design by drastically reducing the flux path length and hence increasing the torque handling ability.
standard flux path
New flux path
A project log for 3D Printed Robot Actuator
A high speed and high torque robotic actuator using low-cost brushless motors, custom controller, 3D printed parts and bearings.
standard flux path
New flux path
really cool. I always wonder if you can make a variable gearbox with magnets..
I think that that has been done in conjunction with a motor called pseudo direct drive.
