Linear PCB Motor vs Flexible PCB Actuator
A project log for Linear PCB Motor
An Open Source Linear Actuator
carl-bugejaCarl Bugeja • 08/09/2018 at 21:20•0 Comments
In this video, I have tested my Flexible PCB actuator and also compared it to my Linear PCB Motor which has the same dimensions but different layer count.
The measured data is shown bellow:
 4-Layer Linear PCB Motor2-Layer Flex PCB Actuator
Resistance32Ω23Ω
Maximum Temperature @ 5V51°C76°C
Power0.75W0.9W
The flex PCB has half the turns, so its resistance is lower. This means that more current can pass through it, so obviously it gets a little hotter. This means that this flexible pcb actuator can be used with lower voltages. The thin dielectric of this pcb also improves the coupling of the magnetic field.
