Linear PCB Motor vs Flexible PCB Actuator
A project log for Linear PCB Motor
An Open Source Linear Actuator
carl-bugejaCarl Bugeja 08/09/2018 at 21:200 Comments
In this video, I have tested my Flexible PCB actuator and also compared it to my Linear PCB Motor which has the same dimensions but different layer count.
The measured data is shown bellow:
 4-Layer Linear PCB Motor2-Layer Flex PCB Actuator
Resistance32Ω23Ω
Maximum Temperature @ 5V51°C76°C
Power0.75W0.9W
The flex PCB has half the turns, so its resistance is lower. This means that more current can pass through it, so obviously it gets a little hotter. This means that this flexible pcb actuator can be used with lower voltages. The thin dielectric of this pcb also improves the coupling of the magnetic field.
Rich text editor
