First Preliminary Test!
06/10/2018 at 22:54 • 0 comments -
PCBs
06/09/2018 at 15:19 • 0 commentsJust received the PCBs from OSH Park!
3D-Printed Slider
06/02/2018 at 15:02 • 0 comments -
3D Rendering
05/25/2018 at 22:00 • 0 comments -
Slider
05/25/2018 at 21:59 • 0 commentsThis is the 3d model of the slider for the first linear pcb motor prototype. This slider houses a 2x20mm diameter neodymium n52 magnet that is used to slide across the pcb by the coil's magnetic fields.
PCB Design
05/16/2018 at 21:33 • 0 commentsFor this project i decided to used 5/5mil traces for the windings on 4-layers, adding to around 140 turns. This design choice makes the coils much bigger than the ones I used for my micro PCB motor (https://hackaday.io/project/39494-pcb-motor) which had 4/4mil traces and around 40 turns.
The bellow 26.7 x 258.2 mm 4-layer pcb with the 12 coils was designed. Thank you oshpark.com for supporting this project.
Concept
05/16/2018 at 21:12 • 0 commentsThe last few weeks I've been thinking about designing a very thin low-torque linear actuator that using pcb trace windings similar my pcb motor project (https://hackaday.io/project/39494-pcb-motor).
My idea is to have 12 vertical coils and alternate their magnetic field and actuate a magnetic rig and slide across the pcb.
