I saw that RaspberryPi.org had an article on JPL Open Source Rover. In the comments section, there was a comment by Daniel Perron (who had also commented on this project page) mentioning Sawppy. I think Daniel should have a project page for his own Sawppy but I haven't seen one under his Hackaday.io account.
Which is a shame, because his rover is making good progress and his work totally deserves attention. So I'm going to draw attention to his build on my Sawppy page here.
Here's a scaled-down copy of the image he linked from his RaspberryPi.org comment. From this picture I can see a few changes from my design. The biggest change is in the structural beams. Daniel is using something other than the Misumi 3-series 15mm extrusion that I used. I'm curious to see how well these beams work. Their uninterrupted square profile should make Daniel's Sawppy more rigid than mine, and more rigidity is always good.
![](https://cdn.hackaday.io/images/7155311533930872814.jpg)
And here's his YouTube clip showing his travel motor turning a wheel under control of his own servo control code.
I'm super excited to see another Sawppy taking form. Your rover looks great, Daniel! Great job and I look forward to seeing your future progress.
Wow I return from vacation and see my own rover on your pages. Weird!! but great.
I didn't do much this summer. it is summer and I was away and I visit some place great.
Misumi extrusion was quit hard to get in Canada and the time for shipping was too long. I decide to use wood instead.
I always had some spare wood and I cut it with my bench saw exactly at the right dimension and when I insert it into the plastic parts they fit very well. The rover looks quite solid even if it is wood frame.
Before my vacation I added my own ball join and I used a 3/8" aluminium rod
https://www.tinkercad.com/things/5MytacBa4Wb-bockle-rocker
This is the picture from my dropbox
https://dl.dropboxusercontent.com/s/s7jgxhfovhyoqsk/IMG_20180901_170044586.jpg
Vacation is done now I will be back on the rover. Next step. will be to add the 4 LX16-A to turn the wheel and test the rover.
Next step will be to add the RPI3B+ computer with DC/DC inverter. I'm thinking of using the Roomba battery pack since I do have two already and it will be simple to create an holder on the rover for it.
