When I work on Sawppy, I test and run indoors. At DTLA Maker Faire Sawppy ran all over, both indoors and out. Most of the time people were playing with Sawppy on a piece of artificial turf at Maguire Gardens. This is an outdoor space where people would walk their dogs, raising obvious sanitation concerns running Sawppy on my home carpet after the event.
Well, after a long day of work, who doesn’t enjoy kicking off their shoes and soaking their feet? I could give Sawppy the same royal treatment. All six wheels were removed and soaked in a tub filled with a mixture of water and household bleach. A retired toothbrush was used to scrub off dirt particles clinging to the wheel. Hopefully this removed most of the contaminants Sawppy might have picked up during the event.
![](https://cdn.hackaday.io/images/3956241543884798044.jpg)
It was also a good time to perform an inspection to see how Sawppy held up mechanically. In addition to the set screw mentioned yesterday, a few chassis mounting screws have fallen out and need to be replaced. I designed plenty of redundancy in these mounts so there was little risk of Sawppy falling apart.
![](https://cdn.hackaday.io/images/3834201543884819041.jpg)
After a few hours of soaking, the wheels were hung up to dry like old socks. What has six rover wheels but is not a rover? This laundry rack.
![](https://cdn.hackaday.io/images/6178481543884837384.jpg)
(Cross-posted to NewScrewdriver.com)
