Low cost robotics platform with builtin camera and WIFI module. Design for testing swarm behaviours, machine learning and Image processing.
This stream covers the followng:
1. test the timing belts as well as the motor.
2. Find a smaller lithium battery
3. Clone the project files
4. Talk about what I'm going to do on the next stream
Here's the second live stream of the project. In this stream I made changes to the robot back axial and dummy wheel and talked about why I'm going to be using timing belts for the robots tracks.
Good news, I've started live streaming the making of the micro robots.
Here's the video to the first live stream I did a few weeks back. In it I introduced the project, made some changes to the tracks and test the motors.
Hi @mrmolamola I wasn't planning on posting instruction just yet. Instead I'm doing live stream of me working on the project.
I figured that when the project was done (or at least good enough), that I would then write up some official build instructions.
Are you ever going to post any instructions or anything? How expensive was it? What parts did you use?
