Revision 3 of the board came in and I quickly soldered it together and it works.
I can control the USB port with either a 3.3V/5V MCU! This should be ideal for automation testing and deploying code.
A project log for USB wedge - 5V power interruptor
This is a simple project to interrupt the power of a USB cable
