As I wrote in details of this project, programming language that I use here came from my "hobby" game "Robot Warfare 1" that I released in 1998 as shareware - it was used to program robots - something like this:
% ================= WSIMPLE.RW1 ==================
% Example of simple robot
% with an eye
% and a gun.
% Run: RW1_DUEL.EXE WSIMPLE.RW1
ROBOT "WinSimple Robot"
COLOR FFD010
FRONT EYE
LEFT GUN
START:
ACT FRONT % Look in front
if N!=6 : L1 % If there is a robot there then
RIGHT
ACT LEFT % shoot
LEFT
GOTO START
L1:
if N!=3 : L3 % If there is a box with missles then
STEP % go ahead
GOTO START
L3: % If there is neither box nor robot then
% it means that there is a barrier in the direction
if D==1 : L4 % If the distance from it is greater then 1 then
STEP % make a step
GOTO START
L4:
RIGHT % If the barrier is in the next cell
GOTO START % turn to right
END
In 1999-2000 I upgraded this programming language for "Robot Warfare 1" v2 to make it more C-like (in the same time I released its compiler as open source software under GPL) - now simplest robot looks like this:
robot "NewSimple"
author "SANYA"
color 000030
front eye
left gun
right gun
+rw1_std.rwi
main()
act front
if(N==@t_robot) call shoot1
else
say "See &N ( &D ) M=&M E=&E !"
if(N==@t_box||D>1) step
else
if(R>500) right
else left
shoot1()
right
A = @left
for(aa=0,aa<3,aa++)
call shoota
left
shoota()
act A
act A
act A
act A
act A
then I created RW1P2 - crosscompiler that compiles robot bytecode to i8080 assembler program using some set of rules and libraries, for example we can have a tile 8x8:
######## => #FF
# # => #81
# # # # => #A5
# # => #81
# # => #81
# ##### => #9F
# # => #81
######## => #FF
with black ink and red paper - it's hexadecimal 40:
;8x8-2/16
;myspr.spr file
MYSPR DB #FF,#81,#A5,#81,#81,#9F,#81,#FF,#40 ;@
then tile compiler will turn it into binary with header file that could be included into the program:
// MY.RW1
robot "MY"
author "Shaos"
+myspr.rwi
main()
dx = 20
dy = 10
for(xx=0,xx<dx,xx++)
for(yy=0,yy<dy,yy++)
select xx yy // choose cell for tile output
set @MYSPR // print tile there
Most significant thing that I did on this programming language was port of "Just Another Tetris" (GPL software by Mattias Wadman) to PetersPlus Sprinter computer in 2002 (and other computers supported by RW1P2):
P.S. Another pretty noisy thing written in this programming language was ASCII PCB and schematics online editor at the end of 2012, but it is totally different story ;)
SHAOS
