Major reincarnation milestone has passed - I was able to compile old test project for all supported platforms (at this moment) - program PRJ/MAPGEN/MAIN.R written in Robby programming language:
robot "MapGen"
author "Shaos"
+INC/ROBBY
+TILES
@DMBOX=10
@DX=20
@DY=10
@SIZE=200
main()
DEF map[@SIZE]
buff = 0
SetRand(14)
_M_reactor = 0x2
_M_hole = 2
_M_box = 5
_M_rock = 20
DEF _X_box[@DMBOX]
DEF _Y_box[@DMBOX]
_N_box = 0;
dx = 0
dy = 0
command @P2_TERMINFO
dx=A;dy=B
x0=(dx-20)/2
y0=(dy-12)/2
A=x0;B=y0;C=2
command @P2_SETSAY
say " ROBOT WARFARE 1 "
A=x0;B=y0+11;C=1
command @P2_SETSAY
SayRand(0)
again:
SayRand(1)
MakeMap(2,@DX,@DY)
kk = 0
for(jj=1,jj<=@DY,jj++)
for(ii=0,ii<@DX,ii++)
c = map[kk]>>4;
kk = kk+1
select(x0+ii,y0+jj)
if(c==0) set @sp_e
if(c==1) set @sp_h
if(c==2) set @sp_s
if(c==3) set @sp_b
if(c==4) set @sp_r
if(c==6) set @sp_r0
while(1)
recv buff
if(buff) break
goto again
+LIB/RANDOM
SayRand()
say "MAPGEN #&RAND "
// A-N, B-X, C-Y
MakeMap()
num = A
dx = B
dy = C
sz = dx*dy
reactor = num * _M_reactor
hole = num * _M_hole
box = num * _M_box
rock = num * _M_rock
for(A=0,A<sz,A++)
map[A] = 0
C = 0
for(B=0,B<rock,B++)
while(map[C])
Random(sz)
map[C] = 0x25
for(B=0,B<hole,B++)
while(map[C])
Random(sz)
map[C] = 0x10
for(B=0,B<box,B++)
while(map[C])
Random(sz)
map[C] = 0x30
if(_N_box<@DMBOX)
_X_box[_N_box]=B%dx
_Y_box[_N_box]=B/dx
_N_box = _N_box+1
for(B=0,B<reactor,B++)
while(map[C])
Random(sz)
map[C] = 0x40
for(B=0,B<num,B++)
while(map[C])
Random(sz)
map[C] = 0x60 + B
Old library LIB/RANDOM.R:
SetRand() // A-RAND
Rand = A
Random() // A-RANGE => C-RESULT L=C
Rand = 0x6255*Rand+0x3619
C = ((Rand&0xFF00)|(((Rand>>8)^Rand)&0x00FF))&0x7FFF
if(A) C=C%A;
return C
Original tiles defined in text file PRJ/MAPGEN/TILES.SPR:
;8x8-2/16
SP_E DB #55,#AA,#55,#AA,#55,#AA,#55,#AA,#F0 ;.!
SP_H DB #55,#BE,#7F,#FE,#7F,#FE,#7D,#AA,#F0 ;O!
SP_S DB #00,#2A,#54,#2A,#54,#2A,#54,#00,#07 ;@
SP_B DB #00,#54,#7E,#54,#54,#7E,#54,#00,#30 ;#!
SP_R DB #00,#76,#6E,#42,#7A,#56,#4E,#00,#CE ;*
SP_F DB #55,#AA,#5D,#BE,#5D,#AA,#55,#AA,#CE ;+
SP_R0 DB #18,#7E,#7E,#3C,#3C,#7E,#7E,#00,#40 ;R!
SP_0 DB #00,#00,#00,#00,#00,#00,#00,#00,#00 ;
SP_1 DB #00,#00,#00,#00,#00,#00,#00,#00,#11 ;.!
Z80 target estex (computer PetersPlus Sprinter from 2002 with Estex operating system):
Z80 target trdos (computer ZX Spectrum with beta-disk interface and TR-DOS operating system):
i8080 target speccy (the same computer ZX Spectrum in original 48k form from 1982, but code was compiled through i8080 assembler and this build uses original ZX Spectrum font):
i8080 target orion (soviet computer Orion-128/256 from 1990 with ORDOS operating system):
i8080 target spetsmx (soviet computer Spetsialist-MX from 1991 that had 16-color graphics):
i8080 target spets (soviet computer Spetsialist from 1987 in original monochrome form):
i8080 target radio (soviet computer Radio-86RK from 1986 that had text mode only):
This target is default one - nedomake will build it if no target is specified - it should be easy enough to create a text suit on it running on GitLab CI/CD after every push to make sure everything is correct...
SHAOS
