all you really need for this is a vinyl blade holder and a short length of tubing.
I used a piece of 3/8ths ID steel tubing but even a pen tube might work if you can find the right diameter.
![](https://cdn.hackaday.io/images/2715841526845116838.jpg)
you can use masking tape to wrap the end of the blade holder to keep it inside the tube instead of set screws.
![](https://cdn.hackaday.io/images/3410461526845139101.jpg)
I drilled and tapped a hole for a set screw on both ends of the tubing one for mounting it to the blade holder and the other I had planned on using to hold pieces of broken carbide drill bits as weights but after testing I found the weight of the holder and the tubing was enough to cut with (1.5oz total without weights)
![](https://cdn.hackaday.io/images/7913551526845073228.jpg)
vinyl cutters usually have adjustable pressure but I can only see that being needed if you were cutting vinyl or paper that wont lay completely flat.
I was able to cut thick cardstock without any major hiccups.
I would highly suggest using a solid surface with a cutting mat for cardstock the board that comes with the axidraw is just too flexible and can cause weird drifting effects.
you will also want to change the "Writing/drawing speed%" down below 20% to start with as well as setting it to "use constant speed when pen is down"
![](https://cdn.hackaday.io/images/9564701526845194431.png)
![](https://cdn.hackaday.io/images/2955691526845210094.png)
![](https://cdn.hackaday.io/images/9365261526845428517.jpg)
![](https://cdn.hackaday.io/images/2066761526845856997.jpeg)
Now, I think Its the device I really need to complete my next art and craft project I am working on right now. I have already ordered adhesive viny
