Ok, I admire that my coding poor, a simple code, that the Maduino zero receives the SMS from a phone, and then controls the connected LED on and off..... The LED turns on when receiving my message:"onr":
#include<stdio.h>
#include<string.h>
#define DEBUG true
int pon=9;
int poff=6;
int lowp=5;
int LED_R= 2;
int LED_G = 3;
int LED_B=4;
String msg = String("");
int SmsContentFlag = 0;
void setup()
pinMode(pon, OUTPUT);
pinMode(poff, OUTPUT);
pinMode(lowp, OUTPUT);
digitalWrite(poff, LOW);
digitalWrite(lowp, HIGH);
digitalWrite(pon, HIGH);
pinMode( LED_R, OUTPUT );
pinMode(LED_G, OUTPUT );
pinMode(LED_B, OUTPUT );
digitalWrite(LED_R, HIGH );
digitalWrite(LED_G, HIGH );
digitalWrite(LED_B, HIGH );
SerialUSB.begin(115200);
while (!SerialUSB) {
; // wait for serial port to connect
Serial1.begin(115200);
poweron();
GprsTextModeSMS();
void loop()
char SerialInByte;
if( SerialUSB.available())
Serial1.print((unsigned char) SerialUSB.read());
else if( Serial1.available())
char SerialInByte;
SerialInByte = (unsigned char) Serial1.read();
if( SerialInByte == 13 )
ProcessGprsMsg();
if( SerialInByte == 10 ){
else {
// EN: store the current character in the message string buffer
msg += String(SerialInByte);
void poweron()
int i=0;
boolean result = false;
digitalWrite(pon, LOW);
delay(3000);
delay(15000);
result = Serial1.find("OK");
if(result)
SerialUSB.println( "Please send sms to control your device!" );
else
for(i=0;i<10;i++)
Serial1.println("AT");delay(500);
if(result)
return;
void ProcessSms( String sms )
SerialUSB.print( "ProcessSms for [" );
SerialUSB.print( sms );
SerialUSB.println( "]" );
if( sms.indexOf("onr") >= 0 ){
digitalWrite(LED_R, LOW);
SerialUSB.println( "LED Red ON" );
// return;
if( sms.indexOf("ong") >= 0 ){
digitalWrite( LED_G, LOW);
SerialUSB.println( "LED Green ON" );
// return;
if( sms.indexOf("onb") >= 0 ){
digitalWrite(LED_B, LOW);
SerialUSB.println( "LED Blue ON" );
// return;
if( sms.indexOf("offr") >= 0 ){
digitalWrite( LED_R,HIGH);
SerialUSB.println( "LED Red OFF" );
// return;
if( sms.indexOf("offg") >= 0 ){
SerialUSB.println( "LED Green OFF" );
// return;
if( sms.indexOf("offb") >= 0 ){
SerialUSB.println( "LED Blue OFF" );
// return;
// EN: Request Text Mode for SMS messaging
void GprsTextModeSMS(){
Serial1.println( "AT+CMGF=1" );
void GprsReadSmsStore( String SmsStorePos ){
// Serial.print( "GprsReadSmsStore for storePos " );
// Serial.println( SmsStorePos );
Serial1.print( "AT+CMGR=" );
Serial1.println( SmsStorePos );
// EN: Clear the GPRS shield message buffer
void ClearGprsMsg(){
msg = "";
// EN: interpret the GPRS shield message and act appropiately
void ProcessGprsMsg()
SerialUSB.println("");
// Serial.print( "GPRS Message: [" );
SerialUSB.print( msg );
// Serial.println( "]" );
if( msg.indexOf( "Call Ready" ) >= 0 )
SerialUSB.println( "*** GPRS Shield registered on Mobile Network ***" );
GprsTextModeSMS();
// EN: unsolicited message received when getting a SMS message
// FR: Message non sollicit茅 quand un SMS arrive
if( msg.indexOf( "+CIEV" ) >= 0 )
SerialUSB.println( "*** SMS Received ***" );
// EN: SMS store readed through UART (result of GprsReadSmsStore request)
if( msg.indexOf( "+CMT:" ) >= 0 )
// EN: Next message will contains the BODY of SMS
SmsContentFlag = 1;
// EN: Following lines are essentiel to not clear the flag!
ClearGprsMsg();
return;
// EN: +CMGR message just before indicate that the following GRPS Shield message
// (this message) will contains the SMS body
if( SmsContentFlag == 1 )
SerialUSB.println( "*** SMS MESSAGE CONTENT ***" );
SerialUSB.println( msg );
SerialUSB.println( "*** END OF SMS MESSAGE ***" );
ProcessSms( msg );
ClearGprsMsg();
// EN: Always clear the flag
SmsContentFlag = 0;
and tomorrow I will try to use its GPRS connection, it seems a challenge to me, as I am a bad firmware engineer and has difficulty reading the English datasheets... and AT commands.... wish my luck.
