A device for decoding very fast 'contest speed' Morse Code.
CW_Decoder_v1.01_KiCad_Files.zipCW Decoder KiCad Files.x-zip-compressed - 88.77 kB - 08/11/2018 at 16:59 |
CW Decoder v1.01_Images.zipA set of various renders and images of the board.x-zip-compressed - 11.97 MB - 08/11/2018 at 16:59 |
CW_Decoder_v1.01_Gerbers.zipGerbers for PCB fabrication.x-zip-compressed - 105.81 kB - 08/11/2018 at 16:57 |
CW Decoder v1.00_BOM.txtBill of Materialsplain - 368.00 bytes - 05/21/2018 at 10:26 |
CW Decoder v1.00.pdfKiCad SchematicAdobe Portable Document Format - 59.20 kB - 05/21/2018 at 10:23 |
I received the PCBs from JLCPCB.com and assembled it with no issues. The LCD Display cabel was easy to make with the right IDC connectors and goes straight from the board to the display.
I found that the receiver's CW filter had to be fairly tight and the tone needs to be fairly accurate, but once it starts decoding, it works well with a good signal.
I have now uploaded the KiCad files, the Gerbers and a set of images for the design.
I've always had a problem with standard LCD displays. I don't know what it is. Maybe the number of connections or the contrast setting, but I always have problems with them. So, when the prototype boards arrived and I soldered one up, I wasn't really surprised to find the display didn't work.
I substuted multiple displays and also swapped out the '328 to a convenient Arduino UNO to make sure it was working. I then re-programmed it with the 'Blink' sketch to flash the Lock LED.
Several hours of frustration later, I realised that the clock oscillator wasn't running. I 'scoped the crystal and nothing. I did attempt to swap the crystal out but being really small connections, the tracks started to lift. I decided to cut my losses and build a new one.
This time, I decided to build in stages. Firstly, I put the 7805 on the board with it's associated components (including the power LED) and checked it worked. Then, the '328 with blink sketch. And then completed the build normally.
After wiring the display and re-programming the '328 with the CW Decode sketch - Success!
So, the moral of the story is, build a bit, check, build another bit, check again... etc.
I have since reworked the display connector and rotated it 180 deg. This will allow a small cable made up from two 16 way IDC connectors to go between the board and the 24x2 line display. A simple adaptor and minor change in the sketch will work with the 16x2 type LCD. The new boards are now on their way from the fabricator.
I love these sorts of things, and it seems like you're making good progress with this project too!
I actually use a Morse Code button to control parts of my DIY smart home. It's nowhere near crazy speeds, but it's still fun ^^
Hi Carl,
75 ICs sounds a lot! Glad it worked well. This project is quite successful if you use some filtering.
Your English is fine :-)
73 de Steve
PCBs have been ordered from JLCPCB.com and I await their arrival to prove the design.
seasleyece
Dimitar
terryspitz
Atheros
man. you got a source code for the 328? ...and you load the fw through the arduino board then swapping the 328 on the pcb I guess..
