26/7 Thursday
- Continue the building of the structure for the platform in the workshop and correct the error measurement.
30/7 Monday
- 3D print out joint model to be put together on the robot and testing out the mechanism on the robot.
- Input coding using arduino board to check the coding.
- Complete the bigger parts of the structure in the workshop, including controller and board for the robot.
1/8 Wednesday
- Connecting the robot's arm with ready 3D printed joints and input coding to run test again.
- Assemble the structure's board with the robot and adjusting the placement of the robots.
- Figuring the placement to hide the wires and board.
- Testing the placement of the LEDs on the structure.
2/8 Thursday
- Debugging codes on the robots.
- Run user test at 3pm to get feedback on the core experience.
