This is a voltage regulator connect the positive end of rectifier to Vin and negative to GND and Vout to the storage in my case powerbank .This will ensure that your power storage is safely and no excess voltage is supplied to the power bank .
Pololu 5V Step-Up/Step-Down Voltage Regulator S7V7F5
