Logic Noise Hack Chat
In this chat we'll be talking about the kinds of sounds you can make from logic chips. Let's make a chip tunes orchestra together!
Friday, June 1, 2018 12:00 pm PDT Local time zone:
Friday, Jun 01 2018, 7:00 pm
Hack Chat
Elliot Williams will be hosting the Hack Chat on Friday, June 1, 2018 at noon PDT.
Time Zones got you down? Here's a handy time converter!
__________________________________________________________________________
Of course you could just take a beautiful-sounding instrument and simply play the right notes. But that’s taking the easy way out. Instead, we'll talk about using basic logic ICs to build something musical or at least interestingly noisy, a tradition that’s as old as the 4000-series chips themselves. We'll look at a handful of Elliot's favorite algorithms and circuits for composing in solder, and if all goes well, “music” will emerge.
Sneak peek: Watch the Live Stream from Hackaday Belgrade where I gave a talk starting at 4:16:30.
Elliot Williams is Hackaday's Managing Editor. After spending eight great years in Washington DC teaching econometrics and working on inflation by day and running a hackerspace by night, Elliot handed in his badge, moved to Munich and started writing as a hacker. He's now living the dream: getting paid to read (and write) Hackaday.
  • Logic Noise Transcript
    Sophi Kravitz06/01/2018 at 20:00 0 comments
    Hello! If you're here for the Hack Chat, put your questions in the comments of this page: https://hackaday.io/event/158624-logic-noise-hack-chat
    but this week, we'll be doing something a little different. Less questions, more listening
    Ted YapoJun-1 2:48 PM
    @ðeshipu forgot to mention you on that
    we'll start the chat a few minutes after the hour
    ðeshipuJun-1 2:49 PM
    I don't actually know the impedance of my speaker
    Ted YapoJun-1 2:49 PM
    that analysis also assumes a 5V supply
    ðeshipuJun-1 2:50 PM
    3.3V supply here
    Ted YapoJun-1 2:50 PM
    you should check.  a 64-ohm speaker won't be loud from that amp, most likely
    I use this: https://www.aliexpress.com/item/AAC-DET402-G-1-Electromagnetic-SMD-Passive-Buzzer-Speaker-3V-120mA-70dB-2731Hz-3x4-5x1-9mm/32800951819.html
    it's quite loud with that amp
    Ted YapoJun-1 2:51 PM
    is it a speaker or buzzer?
    ðeshipuJun-1 2:51 PM
    passive buzzer
    so basically a speaker with non-linear response
    Ted YapoJun-1 2:52 PM
    3V/120mA looks like 25 ohms
    Frank BussJun-1 2:53 PM
    it says "electromagnetic", but looks like a piezo speaker
    ðeshipuJun-1 2:53 PM
    it's electronmagnetic
    I disassembled a few
    Ted YapoJun-1 2:53 PM
    anyway, it looks like you need a sizeable fixed resistor on top of the pot, so the loading on the DAC should be fine
    because they forgot to plug that hole before washing them after assembly, so they rusted inside
    you may need to experiment with the resistor value
    Boian MitovJun-1 2:54 PM
    Hello everyone :-)
    Frank BussJun-1 2:54 PM
    can you hear something with like 200 Hz sine wave? I tried this with a piezo speaker, and it is basically silent at frequencies below 1 kHz
    Frank BussJun-1 2:55 PM
    the lower the more silent :-)
    AlexJun-1 2:55 PM
    Hi
    HI Alex!
    Boian MitovJun-1 2:55 PM
    Well... isn't that exactly the way the sensitivity curve of the ear works?
    I mean for a fixed amplitude....
    Patrick DiJusto joined  the room.Jun-1 2:56 PM
    Frank BussJun-1 2:56 PM
    I can hear a magnetic speaker fine with the same amplitude
    Boian MitovJun-1 2:56 PM
    for low frequencies this is most likely too small amplitude to be able to hear
    not sure then :-(
    WooDWorkeRJun-1 2:56 PM
    @Frank Buss iirc  lower freqencies need more power to be heard equaly loud then higher
    Boian MitovJun-1 2:57 PM
    what is the diameter of the magnetics ?
    @Elliot Williams welcome! we'll start in 7 minutes
    Robley Williams joined  the room.Jun-1 2:57 PM
    It is also matter of how much air volume gets moved
    Frank BussJun-1 2:57 PM
    right, it is the piezo effect, acts like a capacitor, needs higher voltage for the same power
    ðeshipuJun-1 2:58 PM
    @Boian Mitov 3mm
    Boian MitovJun-1 2:58 PM
    3mm diameter of the magnetic...?
    the membrane ?
    Boian MitovJun-1 2:59 PM
    Hello @Sophi Kravitz  :-)
    Elliot WilliamsJun-1 3:00 PM
    Hey all!  For fun, I'll be running a sound stream and taking requests (when feasible) as we go.
    Tune in to http://littlehacks.org:8000/logic_noise.mp3 to hear along.
    !!!! EXCITING !!!! our first Hack Chat with sound
    Boian MitovJun-1 3:00 PM
    Cool! :-)
    let's start in about 4 minutes tho, give more people a chance to get here
    fresal joined  the room.Jun-1 3:00 PM
    See if you can crash my Icecast server!  :)
    HAHA
    this sounds great!
    Robley WilliamsJun-1 3:02 PM
    Cool melody!
    ðeshipuJun-1 3:03 PM
    Adam Vadala-RothJun-1 3:03 PM
    hello hello!!!
    @Boian Mitov it looks like this inside (next to the switch) --^
    after removing the case and the membrane
    Boian MitovJun-1 3:03 PM
    @ðeshipu Nice...! :-)
    Adam Vadala-RothJun-1 3:04 PM
    its synth time
    ðeshipuJun-1 3:04 PM
    that's the rusty one, of course
    I made a photo to show the people in the fab
    Ted YapoJun-1 3:04 PM
    it's always synth time
    I's the OFFICIAL synth time
    sorry, I'm shutting up...
View event log
Enjoy this event?
Rich text editor
Frank Buss wrote 06/01/2018 at 16:20 point
What's the point of using logic ICs for sound synthesis, if you can do it all in even small microcontrollers, and much better?
AVR wrote 06/01/2018 at 16:43 point
A lot of folk in the synth community including myself prefer the sound of all analog synthesis, it just sounds bigger and better to me.
Frank Buss wrote 06/01/2018 at 16:51 point
I'm sure in a double blind test you wouldn't hear the difference.
Ted Yapo wrote 06/01/2018 at 17:30 point
Is it kind of like why use tubes when you can get less distortion with transistors?
AVR wrote 06/01/2018 at 18:37 point
yeah its really all about the difference ways you can connect modules and overdrive them to create different sounds. There is a reason KORG and MOOG are printing money right now.
Elliot Williams wrote 06/01/2018 at 18:41 point
Interactivity.  When your sounds have to be coded, the "what happens if" loop takes a very long time to come full circle.  Much of the time, especially with modular-style setups, feedback is so much more immediate with the physical devices.  And that makes it just that much more enjoyable/creative.
But I do both.  :)
Frank Buss wrote 06/01/2018 at 18:49 point
That's just bad programming. For example you can use an accumulator and a phase shift value, which can be modulated very immediately. Of course, you shouldn't do a for loop and only test at the end for user signal or modulation changes.
AVR wrote 06/01/2018 at 18:50 point
I am with you there!  On this topic I always think about how one of modules int he MOOG model D has more gain than it should but as a result there is a warm overdrive when that module drives another and they kept the mistake cause it sounded awesome!
join The Synthesizer Freaks facebook group to learn why Analog is king!!! Or get one of the following:
Aturia Microbrute
Korg Monologue
Moog Mother32
smartalyx wrote 05/28/2018 at 17:26 point
Are there any items we should 'bring'?
Elliot Williams wrote 05/31/2018 at 19:41 point
Not really, but what the heck!  :)
A breadboard, a few 100 k potentiometers (or a good supply of random resistors), 0.1 uF capacitors (and/or a range of 1 uF to 0.01 uF), diodes, jumper wires, and whatever logic chips you've got on hand?
I put out a (huge?!) parts list at the end of this installment: https://hackaday.com/2015/07/02/logic-noise-ping-pong-stereo-mixers-and-more/  But that's more like everything you'd want for a lifetime of fun.
If you're just getting started, an inverter is a must.  40106 or 74xx14 will do you.  A 4093 NAND with schmitt trigger is just as good.
Interested in attending?
Become a member to follow this event or host your own
