The second , most important part of the muscle module is the bidirectional , miniature gear pump . After a lengthy search I found a pump which is almost perfect for this project - a miniature gear pump made by MAGOM HRC company , and intended to be used in RC construction machinery models.
The last step is to install the BLDC motor. If the motor does not fit the pump it may be required to build an adapter and modify the original mount ( as it was it my case ) .
