23 July (Monday)
15th Group Meeting & Discussion
- We started to use the templates A and B and cut out the pieces.
- We took turns tracing on the board and cut it out using the cutter. It took hours but we managed to finished cutting out all the triangle pieces. 28x of template A and 9x of template B. There will be also some extras incase there is a mistake during the process.
- After that, we experimented on different things to make the folding line. When experimenting for awhile we managed to make a dent using an metal panel and a hammer.
- We also did a time lapse of the whole process.
25 July (Wednesday)
16th Group Meeting & Discussion
- Started painting all the triangle panels B with black paint.
- Finish scoring all the triangle panels A and ready to be painted on the next day.
26 July (Thursday)
17th Group Meeting & Discussion
- We confirm with lecturers about our changes in the user interaction. Our programmer later on start researching on the coding part of the new interactions.
- After finishing making all the triangles for the roof we move on with fabricating the walls of the structure.
- We cut out the shapes, make the folding lines and paint the panels.
- We try to make haste since next week is the user test.
Meryl Lee
