This are all the codes we used for making this whole project possible. And all the code here are used in Ardiuno.
LED Control
#include <Adafruit_NeoPixel.h>
//LED
#define PinA 6 //WindowLight 4
#define PixelsA 24
#define PinC 7 //WindowLight 40
#define PixelsC 156
#define PinB 5 //StarLight
#define PixelsB 400 // total stars
int starsIncrement = 0;
int starsLighted = 0;
Adafruit_NeoPixel stripA = Adafruit_NeoPixel(PixelsA, PinA, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel stripC = Adafruit_NeoPixel(PixelsC, PinC, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel stripB = Adafruit_NeoPixel(PixelsB, PinB, NEO_GRB + NEO_KHZ800);
//Sensor
#define trigPin 13
#define echoPin 11
//boolean windowTrigger = false;
boolean sensorStart = false;
//Star Light
float redStates[PixelsB];
float blueStates[PixelsB];
float greenStates[PixelsB];
float fadeRate = 0.96;
//Window Light
#define waitTime 2
// 4 LED
byte buttonPins[] = {
22, 24, 26, 28, 30,
32
// 34, 36, 38, 40,
// 42, 44
//46, 48, 50,
//52, 31, 33, 35, 37,
//39, 41, 43, 45
boolean windowStatesT0[] = {
1, 1, 1, 1, 1,
1, 1
//, 1, 1, 1,
// 1, 1
//1, 1, 1,
//1, 1, 1, 1, 1,
//1, 1, 1, 1
boolean windowStatesT1[] = {
1, 1, 1, 1, 1,
1, 1
//, 1, 1, 1,
//1, 1,
//1, 1, 1,
//1, 1, 1, 1, 1,
//1, 1, 1, 1
// 12 LED
byte buttonPins2[] = {
// 22, 24, 26, 28, 30,
// 32, 34, 36, 38, 40,
// 42, 44
46, 48, 50, 52, 31,
33, 35, 37,//
//39, 41, 43, 45
boolean windowStatesT2[] = {
1, 1, 1, 1, 1,
1, 1, 1
//1, 1, 1, 1
//1, 1, 1,
//1, 1, 1, 1, 1,
//1, 1, 1, 1
boolean windowStatesT3[] = {
1, 1, 1, 1, 1,
1, 1, 1
//1, 1, 1, 1,
//1, 1, 1,
//1, 1, 1, 1, 1,
//1, 1, 1, 1
void setup() {
//Light A
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(PinA, OUTPUT);
stripA.begin();
stripA.show();
pinMode(PinB, OUTPUT);
stripB.begin();
stripB.show();
pinMode(PinC, OUTPUT);
stripC.begin();
stripC.show();
starsLighted = 0;
starsIncrement = int( PixelsB / sizeof(windowStatesT0) );
//Window Buttons
//4
for ( int i = 0; i < sizeof(buttonPins); i++ ) {
pinMode(buttonPins[i], OUTPUT);
digitalWrite(buttonPins[i], HIGH);
//12
for ( int i = 0; i < sizeof(buttonPins2); i++ ) {
pinMode(buttonPins2[i], OUTPUT);
digitalWrite(buttonPins2[i], HIGH);
Serial.begin (9600);
void loop() {
sensorTrigger();
if (starsLighted > 0) {
starLight();
checkButtons();
// checkButtons2();
void(* resetFunc) (void) = 0;
Sensor Trigger
void sensorTrigger() {
//setGateway(13);
float duration, distance;
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
//setGateway(14);
duration = pulseIn(echoPin, HIGH, 1000);
if (duration > 0) {
distance = (duration / 2) * 0.0344;
else {
distance = 999;
if (sensorStart == false) {
if (distance <= 10) {
for ( int i = 0; i < sizeof(windowStatesT0); i++ ) {
//windowFadeIN(255, 127, 0, waitTime, i);
windowFadeIN2(255, 127, 0, waitTime, i);
sensorStart = true;
Serial.println("Hello");
//colorWipe(stripB.Color(127, 127, 127), 50); // Red
if (sensorStart == true) {
if (distance >= 10) {
//Serial.println("END");
resetFunc();
//sensorStart = false;
delay(50);
Stars Light
void starLight() {
constrain(starsLighted, 0, PixelsB);
int probabilityMargin = PixelsB / starsLighted;
if (random(probabilityMargin) <= 1) {
int i = random(0, starsLighted);
redStates[i] = 50;
greenStates[i] = 50;
blueStates[i] = 50;
int i2 = random(0, starsLighted);
redStates[i2] = 50;
greenStates[i2] = 50;
blueStates[i2] = 50;
int i3 = random(0, starsLighted);
redStates[i3] = 50;
greenStates[i3] = 50;
blueStates[i3] = 50;
int i4 = random(0, starsLighted);
redStates[i4] = 50;
greenStates[i4] = 50;
blueStates[i4] = 50;
int i5 = random(0, starsLighted);
redStates[i5] = 50;
greenStates[i5] = 50;
blueStates[i5] = 50;
int i6 = random(0, starsLighted);
redStates[i6] = 50;
greenStates[i6] = 50;
blueStates[i6] = 50;
for (int l = 0; l < starsLighted; l++) {
if (redStates[l] > 1 || greenStates[l] > 1 || blueStates[l] > 1) {
stripB.setPixelColor(l, redStates[l], greenStates[l], blueStates[l]);
if (redStates[l] > 1) {
redStates[l] = redStates[l] * fadeRate;
delay(1);
} else {
redStates[l] = 0;
if (greenStates[l] > 1) {
greenStates[l] = greenStates[l] * fadeRate;
delay(1);
} else {
greenStates[l] = 0;
if (blueStates[l] > 1) {
blueStates[l] = blueStates[l] * fadeRate;
delay(1);
} else {
blueStates[l] = 0;
} else {
stripB.setPixelColor(l, 0, 0, 0);
stripB.show();
delay(5);
Window Fade In
void windowFadeIN(int red, int green, int blue, int wait, int thatFirstLED) {
for (int b = 0; b < 255; b++) {
int theFirstLED = thatFirstLED * 4;
for (int pixID = theFirstLED ; pixID < theFirstLED + 4; pixID++) {
// stripA.setBrightness(100);
// stripA.setPixelColor(pixID, red * b / 255, green * b / 255, blue * b / 255);
// stripA.show();
stripA.show();
delayMicroseconds(100);
void windowFadeIN2(int red, int green, int blue, int wait, int thatFirstLED) {
int theFirstLED = thatFirstLED * 40;
for (int pixID = theFirstLED ; pixID < theFirstLED + 40; pixID++) {
stripC.setBrightness(100);
stripC.setPixelColor(pixID, red * b / 255, green * b / 255, blue * b / 255);
stripC.show();
Window Fade Out
void windowFadeOUT(int red, int green, int blue, int wait, int thatFirstLED) {
for (int b = 255; b > 0; b--) {
// int theFirstLED = thatFirstLED * 4;
int theFirstLED = thatFirstLED * (PixelsC / 6);
// for (int pixID = theFirstLED ; pixID < theFirstLED + 4; pixID++) {
for (int pixID = theFirstLED ; pixID < theFirstLED + (PixelsC / 6); pixID++) {
// stripA.setBrightness(50);
stripC.setBrightness(50);
// stripA.show();
stripC.show();
delay(wait);
void windowFadeOUT2(int red, int green, int blue, int wait, int thatFirstLED) {
stripC.show();
delay(wait);
Check Buttons
// 4 Window Light
void checkButtons() {
// Serial.print(i); Serial.print("\t");
// Serial.println(digitalRead(buttonPins[i]));
if ( digitalRead(buttonPins[i]) == LOW ) {
windowStatesT1[i] = 0;
updateWindowLights();
void updateWindowLights() {
if ( windowStatesT1[i] == 0 && windowStatesT0[i] != 0 ) {
windowFadeOUT(255, 127, 0, waitTime, i);
windowStatesT0[i] = 0;
starsLighted += starsIncrement;
if ( starsLighted >= PixelsB ) {
starsLighted = PixelsB;
// 12 Window Light
void checkButtons2() {
if ( digitalRead(buttonPins2[i]) == LOW ) {
windowStatesT3[i] = 0;
updateWindowLights2();
void updateWindowLights2() {
for ( int i = 0; i < sizeof(windowStatesT2); i++ ) {
if ( windowStatesT3[i] == 0 && windowStatesT2[i] != 0 ) {
windowFadeOUT2(255, 127, 0, waitTime, i);
windowStatesT2[i] = 0;
Testing
void colorWipe(uint32_t c, uint8_t wait) {
for(uint16_t i=0; i<stripB.numPixels(); i++) {
stripB.setPixelColor(i, c);
stripB.show();
delay(wait);
