I am actually on my second revision of this board. The initial revision had a place for a 0805 Resistor which turned out to be unnecessary. Of the 140ish I'll be bringing to DEF CON approximately 45 will have a ZERO OHM Jumper where a resistor would have been.
The second revision doesn't have this and I carried this knowledge over to my second shitty add-on.
