Hackaday.io Hackaday.io
Sign up Log in
ASV or Autonomous Surface Vehicle Platform
Autonomous Surface Vehicle Platform for oceanography or inspections of ports and harbours
ap-techap-tech
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3k views
0 comments
11 followers
  • Description
  • Details
  • Files 0
  • Components 7
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
  • 2021 Hackaday Prize
View Gallery
3k
0
11
5
Team (1)
  • ap-techap-tech
Join this project's team
hardware
ongoing project
2021hackadayprize
This project is submitted for
  • Hackaday.com Tip Line
  • Beautiful Hardware
  • Challenge 4: Redefine Robots
This project was created on 05/30/2018 and last updated 3 years ago.
Description
This is an Autonomous Surface Vehicle Platform or sea drone, On top is a 340X240X155mm IP67 hinged plastic enclosure Where you can put your own electronic controls, The boat body is a foam core fibreglass and plywood construction, Surfboard technology, The boat foam core body alone is 1170X450X130mm, With all the parts on the boat (The IP67 Box and the outboard system) the boat's length is 1270mm and the hight is 280mm so over all the boat is 1270X450X280mm. I'm selling the Outboard system as kit on Tindie check it out. https://www.tindie.com/products/AP_tech/outboard-system-kit-for-asvs/ or you can downloaded it from https://cults3d.com/en/3d-model/gadget/outboard-system-kit-for-asvs We are now also selling the ASV itself as a prototyping platform but you can talk to us if you need some custom electronics. https://anthonypirotta.wixsite.com/website
Details
https://www.youtube.com/watch?v=y9cJWtHKvms&feature=share&fbclid=IwAR2Z
3MzgbYhqdo8GsxUlt_UMIe5hafJ0tDNb4syFMMNF3ZcT5DL6c
Components
  • 1 × T200 Thruster https://www.bluerobotics.com/store/thrusters/t100-t200-thrusters/t200-thruster/
  • 3 × SAMD21 Breakout Board https://www.tindie.com/products/AP_tech/samd21-breakout-board/
  • 1 × GPS Module https://www.ebay.com/itm/Ublox-NEO-6M-GPS-Module-GY-NEO6MV2-Flight-Controller-For-Arduino-MWC-IMU-APM2/263109626852?hash=item3d4
  • 2 × DC-DC Step-Down Buck Converter https://www.ebay.com/itm/3-40V-DC-DC-Step-Down-Buck-Converter-Inverter-Power-Module-Voltage-Regulator-/272685424222?hash=item3f7d515e5e
  • 1 × XBee pro https://eu.mouser.com/ProductDetail/digi-international/xbp24cauit-001/?qs=%2fPVulymFwT1oQlHUwvmBKA%3d%3d&countrycode=US¤cycode=USD
View all 7 components
Log In/Sign up to comment
Sign up with Github
OR
Low cost platform
Project Owner Contributor
Box wing Drone
sam-fergusonSam Ferguson
Custom designed and built desk from steel box section and a length of beech kitchen worktop.
Steel and beech desk.
robert-whiteRobert White
Puzzles
jlamJLAM
An autonomous structure that auto-deploys and retracts to make the inaccessible, accessible.
Roving walkways and stairways
willy-aenllewilly aenlle
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ASV or Autonomous Surface Vehicle Platform", please tell us the reason.
Send message
Remove Member
