我的目的是为了制作一个在白天使用太阳来加热,通过湿度传感器控制加湿器的烟草发酵箱。箱子的主体是一个泡沫箱,我在里面铺上了锡箔(也可以是铝箔),箱子的开口使用了保鲜膜封住。这样可以更多的吸收太阳的热量,同时不让热量太快的流失。同时我使用8266模块,我可以在办公室来监测数据(io.adafruit)。目前我的设备已经开始运行。但是湿度变化曲线不是很理想。我就会调整我的代码来使湿度曲线更加的平滑。同时,目前的最高温度记录为44摄氏度,也没有达到目标的50度。英语不是我的母语,并且我也不想用英语来写这些,这对我来说太难了。所以提供了GOOGLE翻译的英文版本。
My purpose is to make a tobacco fermentation tank that uses the sun for heating during the day and controls the humidifier through a humidity sensor. The main body of the box is a foam box. I put a tin foil (which can also be aluminum foil) inside, and the opening of the box is sealed with a plastic wrap. This can absorb more of the sun's heat without losing too much heat. At the same time I use the 8266 module and I can monitor data (io.adafruit) in the office. At present my equipment has already started running. However, the humidity curve is not ideal. I will adjust my code to make the humidity curve smoother. At the same time, the current maximum temperature record is 44 degrees Celsius, and it has not reached the target of 50 degrees. English is not my mother tongue, and I don't want to write this in English. It's too hard for me. So the English version of GOOGLE Translator is provided.
sunny
littleBits
The Spanner
Joseph Marlin
