Raspberry Pi Zero: Controller Loop Stability
A project log for LabRATory Telepresence Robot
This robot moves vicariously for a laboratory mouse while its brain is imaged by a microscope!
brett-smithBrett Smith • 02/07/2019 at 12:52•0 Comments
Raspberry Pi Zero: Controller Timing Stability
Servo motor control is usually implemented with an embedded MCU as typically very fast, consistant control loops are required for real life motion controls. Programming, capturing data, and PID tuning can be tedious in an embedded system environment. So in this notebook we will be examining raspberry pi zero loop stability while controlling a brushed, dc motor.We will be testing the loop timing under different conditions:
1) Executing normally
2) Executing as an individual python thread
3) Executing during video streaming
4) Executing with multiple controller threads
5) Executing with overclocked CPU
Procedure
Because this platform is ultmately being developed for a raspbery pi robot with a live video stream using gstreamer, I will test the loop time both while the raspberry pi is streaming and not streaming video. A total of 8 tests were performed in a variety of combinations of the above conditions. Those conditions can be seen in the table below:
Video Not Streaming Video Streaming Overclocked CPU: Video Not Streaming
Main Loop Test 1 Test 3 Test 7
Threaded Loop Test 2 Test 4 Test 8
5 Threaded Controllers Not Tested Test 5 Test 9
2 Threaded Controllers Not Tested Test 6 Test 10
We will build a list of execution times for each testing state and analyze the distribution of those execution times. This will enable us to analyze the frequency and stability of the control loop.
Software
The raspberry pi is using berryconda to manage python virtual environments, and is running a native jupyter notebook server to allow quick code editing and easy data capture.
Hardware
Between the raspberry pi there is a micrcontroller and an h-bridge. The microcontroller is setup to measure encoder counts and send them when requested to the Raspberry Pi. Likewise, the microcontroller listens to the serial line and sets the motor direction and PWM based off raspberry pi commands.
IMG-20190207-142511
In [43]:
#! /home/pi/berryconda3/envs/pidtuner/bin/python
%matplotlib inline
import matplotlib
import seaborn as sns
import matplotlib.pyplot as plt
import serial
import time
import RPi.GPIO as GPIO
import atexit
import random
import threading
import numpy as np
from scipy.stats import norm
from scipy import stats
In [3]:
ser = serial.Serial(
port = '/dev/ttyS0',
baudrate = 115200,
bytesize = serial.EIGHTBITS,
parity = serial.PARITY_NONE,
stopbits = serial.STOPBITS_ONE,
timeout = 1,
xonxoff = False,
rtscts = False,
dsrdtr = False,
writeTimeout = 2
In [4]:
def setPwm(pwm):
    message = str.encode('R' + str(pwm) + '!')
    ser.write(message)
def getRevs():
    ser.write(str.encode('?!'))
    val = ser.readline()
    return (int(val))
In [5]:
class PID (threading.Thread):
    setpoint = 0
    last = 0
    error = 0
    lastValue = 0
    Tkp = 0
    Tki = 0
    Tkd = 0
    def __init__(self, kp, ki, kd, direction, outputFunc, inputFunc, threadID):
        threading.Thread.__init__(self)
        self.kp = kp
        self.ki = ki
        self.kd = kd
        self.direction = direction
        self.threadID = threadID
        self.outputFunc = outputFunc
        self.inputFunc = inputFunc
        self.output = 0
        #Used for thread timing
        self.count = 0
        self.runtimes = []
        #This is used to terminate the thread
        self.shutdown_flag = threading.Event()
        self.min = 0
        self.max = 0
    def join(self, timeout=None):
        self.shutdown_flag.set()
        threading.Thread.join(self, timeout)
    def setLimits(self, outputMin, outputMax):
        self.min = outputMin
        self.max = outputMax
    def __run__(self):
        controllerInput = self.inputFunc()
        controllerOutput = self.compute(controllerInput)
        self.outputFunc(controllerOutput)
    def run(self):
        while not self.shutdown_flag.is_set():
            #self.__run__()
            dt = self.timeFunc(self.__run__)
            self.runtimes.append(dt)
            self.count += 1
    def timeFunc(self, func):
        start = time.monotonic()
        func()
        return time.monotonic() - start
    def compute(self, value):
        #update timer
        now = time.monotonic()
        dt = now - self.last
        self.last = now
        #update PID terms
        self.error = self.setpoint - value
        self.Tkp =  self.kp*self.error
        self.Tki += self.ki*self.error*dt
        self.Tkd =  self.kd*(value - self.lastValue)/dt
        self.lastValue = value
        output = self.Tkp + self.Tki - self.Tkd
        if output < self.min:
            output = self.min
        if output > self.max:
            output = self.max
        self.output = output*self.direction
        return(self.output)
In [6]:
pid1 = PID(17,0,0.16, -1.0, setPwm, getRevs, 'pid1')
pid1.setLimits(-1000.0, 1000.0)
pid1.setpoint = getRevs()
@atexit.register
def exit():
    setPwm(0.0)
    pid1.shutdown_flag.set()
    pid1.join()
    ser.close()
    GPIO.cleanup()
    print('PID test ended.')
Test 1: Main Loop Execution, No Video Stream
In [7]:
def mainTest():
    count = 0
    main_loop_times = []
    pid1.setpoint = getRevs() - 625
    while count < 1000:
        pid1.__run__()
        main_loop_times.append(time.monotonic() - now)
        count += 1
    setPwm(0.0)
    return main_loop_times
In [37]:
data1 = mainTest()
mu, std = norm.fit(data1)
sns.distplot(data1)
print('Mean',mu)
print('Standard Deviation', std)
print('Number Samples', len(data1))
fig = plt.figure()
ax = fig.add_subplot(111)
stats.probplot(data1, dist=stats.loggamma, sparams=(2.5,), plot=ax)
plt.show()
Mean 0.0073300706770123725
Standard Deviation 0.0009723582933104428
Number Samples 1000
Test 2: Threaded Execution, No Video Stream
In [9]:
def threadTest():
    pid = PID(17,0,0.16, -1.0, setPwm, getRevs, 'pid1')
    pid.setLimits(-1000.0, 1000.0)
    pid.setpoint = getRevs() - 625
    count = 0
    thread_loop_times = []
    pid.start()
    while(pid.count < 1000):
        time.sleep(0.01)
    pid.shutdown_flag.set()
    pid.join()
    return pid.runtimes
In [38]:
data2 = threadTest()
mu, std = norm.fit(data2)
sns.distplot(data2)
print('Mean',mu)
print('Number Samples', len(data2))
fig = plt.figure()
stats.probplot(data2, dist=stats.loggamma, sparams=(2.5,), plot=ax)
plt.show()
Mean 0.007794305371624852
Standard Deviation 0.0009235506427647417
Number Samples 1001
Test 3: Main Loop Execution, Video Streaming
In [13]:
data3 = mainTest()
mu, std = norm.fit(data3)
plt.hist(data3, bins=100, density=True,  color='g')
plt.show()
print('Mean',mu)
print(len(data3))
Mean 0.009181247276006615
Standard Deviation 0.0032182004652700565
1000
Test 4: Threaded Execution, Video Streaming
In [14]:
data4 = threadTest()
mu, std = norm.fit(data4)
plt.hist(data4, bins=100, density=True,  color='g')
plt.show()
print('Mean',mu)
Mean 0.009382372759245373
Standard Deviation 0.003445627311796786
Test 5: 5 Threaded Execution: Video Streaming
In [33]:
def fakeFoo(var):
    return 0
def fakeFoo2():
    return 0
In [31]:
def multiThreadTest(numThreads, waitCounts):
    pids = []
    data = []
    count = 0
    pid = None
    pid = PID(2,0,0.0, -1.0, setPwm, getRevs, 'pid'+str(count))
    pids.append(pid)
    count += 1
    while(count < numThreads):
        pid = None
        pid = PID(17,0,0.16, -1.0, fakeFoo, fakeFoo2, 'pid'+str(count))
        pids.append(pid)
        count += 1
    for pid in pids:
        pid.start()
    print('Threads Spawned')
    while(pids[0].count < waitCounts):
        time.sleep(0.01)
    print('Done Waiting')
    for pid in pids:
        pid.join()
    print('Threads shutdown')
    for pid in pids:
        data += pid.runtimes
    setPwm(0.0)
    return pids[0].runtimes
In [36]:
data = multiThreadTest(5,100)
mu, std = norm.fit(data)
sns.distplot(data)
print('Mean',mu)
print('Number Samples', len(data))
fig = plt.figure()
stats.probplot(data, dist=stats.loggamma, sparams=(2.5,), plot=ax)
plt.show()
Threads Spawned
Done Waiting
Threads shutdown
Mean 0.2168126435098398
Standard Deviation 0.09721862391775106
Number Samples 1000
The running time is almost 10x greater spawing 5 of the threads! This greatly affects controller performance. According to 'top' this program was occupying 85% of CPU overhead. Although even single threaded tasks seem to occupy this much overhead.
Test 6: 2 Threaded Execution, Video Streaming
In [35]:
data = multiThreadTest(2,1000)
sns.distplot(data)
print('Mean',mu)
fig = plt.figure()
plt.show()
Threads Spawned
Done Waiting
Threads shutdown
Mean 0.017995777843166767
Standard Deviation 0.008524876724822198
Number Samples 1000
Two threads (which we will need) has much better loop time although the CPU overhead is still comparable.
Pi Overclocked to 800 MHz
I wasn't thrilled with the update rate of the control loop, and the amount of processor overhead, so I tried overclocking the pi from 700 MHz to 800 MHz
Test 7: Pi Overclocked, Main Thread, No Video Stream
In [25]:
## Main Thread : No Video Stream
data5 = mainTest()
mu, std = norm.fit(data5)
sns.distplot(data5)
print('Mean',mu)
print(len(data5))
fig = plt.figure()
stats.probplot(data5, dist=stats.loggamma, sparams=(2.5,), plot=ax)
plt.show()
Mean 0.007363954764970913
Standard Deviation 0.0009171446874688051
1000
Test 8: Pi Overclocked, Threaded Execution, No Video Stream
In [40]:
## Threaded: No Video Stream
data6 = threadTest()
mu, std = norm.fit(data6)
sns.distplot(data6)
print('Mean',mu)
print('Number Samples', len(data6))
fig = plt.figure()
stats.probplot(data6, dist=stats.loggamma, sparams=(2.5,), plot=ax)
plt.show()
Mean 0.007800759974014982
Standard Deviation 0.0009823091864072152
Number Samples 1001
Test 9: Pi Overclocked, 5 Controller Threads, No Video Stream
In [42]:
## 5 Threaded Overclock, No Video Stream
sns.distplot(data)
print('Mean',mu)
fig = plt.figure()
plt.show()
Threads Spawned
Done Waiting
Threads shutdown
Mean 0.14593184682352706
Standard Deviation 0.06581780544764805
Number Samples 102
Test 10: Pi Overclocked, 2 Controller Threads, No video Stream
In [41]:
## 2 Threaded Overclock: No Video Stream
s
