Down the Rabbit Hole and Back Again
Well, I got a bit distracted.
After the last log entry, I felt I was ready to embark on the second major phase of the project, in which I plan to build a second Logisim model based on real-world parts rather than generic Logisim ones.
I also want to be able to print out schematics from Logisim and use them to build from, which means showing pin numbers on schematic symbols, assigning designation numbers to components, etc. While these things can be done, Logisim doesn't give you much help with them. And there are complications – for example, a 7400 consists of four gates with different pin numbers, which means I would need to create four different library components for it, and be careful to use the right ones in the right places and not use the same gate twice or miss using a gate that I could have used. All very tedious and error-prone.
So, since Logisim is open source, I decided to take a couple of weeks to see if I could add a few things to it to make my life easier.
A few months later...
I now have a fork of Logisim-evolution that I'm calling Logisim-CAD. It allows a single library component to represent a part with multiple units. It has an auto-numbering feature that understands the multi-unit components. It also has a few tweaks to the rendering so that printed schematics come out looking nicer. For full details see the Readme on the Logisim-CAD Github page
Main Memory, Memory Timing and Refresh Timing
This is the first chunk of the Phase 2 model. It contains the DRAMs, timing DRAM cycles, and the timing chain that both refreshes the DRAM and generates data for the oscilloscope display.
I've divided the schematic into three parts here, although it's currently a single subcircuit in the Logisim model.
There are two layers of multiplexers. U103, U105, U108 and U111 select either the CPU or display/refresh address. There are 15 address bits, leaving one input spare that is used to multiplex the write signal. U104 and U109 select the row and column addresses for the RAMs.
U102a latches data read from the RAM during CPU memory cycles.
This is the timing chain for memory cycles. A 16MHz clock input is divided by U113a to give two 8MHz clocks of opposite phases. One of them drives U114a and b, which form a 4-state ring counter that generates the RAS (Row Address Strobe) and CAS (Column Address Strobe) for the RAMs. U113b is clocked from the other 8MHz phase and produces a signal that changes mid way between the falling edges of nRAS and nCAS; this is used to drive the row/column address multiplexers.
U115a is toggled for each memory cycle and partitions them into CPU cycles (TCPU) and display/refresh cycles (TREF). U115b further partitions the CPU cycles into read cycles (TCPURD) and potential write cycles (TCPUWR).
U102b synchronises the input from the reset switch so that the system-wide reset signal (nRESET) is released between active edges of the 8MHz clock, to ensure that everything starts off cleanly following a reset. I'm not sure if this is strictly necessary, but it seems like a good idea.
U115b also performs another function. U115b and U122 form a 5-bit counter configured to count from 0 to 17; this generates the display/refresh bit address (REFBIT). U116 and U123 form a 6-bit counter ranging from 0 to 43, from which the display/refresh word address (REFWRD) is derived. Each line of the display contains two words, so the upper 5 bits of REFWRD represent the display line number, ranging from 0 to 21. The first 16 lines show the page of memory selected by the TANK inputs, and the rest show data from the registers.
Also generated here are the display register file address (DSPRFA) and two synchronising signals for the display raster generator (DSPHSYNC and DSPVSYNC).
U120 combines the various sources of display data and produces a display video signal (DSPDAT). It consists of a short pulse at the end of each TREF cycle where a 1 is to be displayed. This will be connected to the Z input of the scope to produce bright dots on the screen.
