About EDSAC
A project log for BREDSAC
Electronic Dynamic Storage Breadboard Computer
gregewinggreg.ewing 06/02/2018 at 07:410 Comments
This is a very brief description of the EDSAC architecture. Much more information can be found in the references listed below.
Memory
The main memory consists of 1024 words of 18 bits each. It can be
accessed as short words of 17 bits or long words of 35 bits (one bit of
each word being unused for timing reasons).
Registers
Name Size Usage
Program Counter 10 bits Address of next instruction to be executed
Accumulator 71 bits Holds results of arithmetic and logical operations
Multiplier 35 bits Holds one of the operands for a multiplication
The original machine had some other registers that are not listed here
beause they were not directly visible to the programmer. It is possible
that they will not have direct equivalents in my version.
Data Formats
Short and long words can represent integers or fractions. Fractional
numbers are assumed to be in the range -1 <= x < 1, with an
implied binary point between the sign bit and the most significant bit.
Negative numbers use two's-complement representation.
Additions, subtractions and logical operations operate on the most
significant 17 or 35 bits of the accumulator. Multiplication assumes
both operands are fractions as above. Short multiplication produces a
35 bit result, and long multiplication produces a 71 bit result.
Instruction Format
All instructions occupy one short word and have the following fields.
Field Opcode Spare Address Length
Bits 5 1 10 1
The Opcode indicates the operation to be performed. Many of the
opcodes are chosen to have mnemonic value when interpreted as 5-bit
teleprinter character codes (e.g. "A" = add).
The Spare bit was unused in the original (1949) version of the machine.
The Address field contains the absolute address of the operand in memory.
The Length bit indicates whether a short word (0) or a long word (1) is
to be operated on. Long words occupy an even-odd address pair with the
least significant half at an even address.
Instruction Set
Notations used in this table:
n Address field of the instuction
C(n) Contents of memory location n
f Length indicator
k A shift amount, encoded by setting bit number k-1 of the instruction
Instruction Description
A n f Add C(n) to the accumulator
S n f Subtract C(n) from the accumulator
H n f Load C(n) into the multiplier register
V n f Multipy C(n) by multiplier and add result to accumulator
N n f Multipy C(n) by multiplier and subtract result from accumulator
T n f Transfer accumulator to memory location n and clear the accumulator
U n f Copy accumulator to memory location n
C n f Logical AND ("collate") C(n) with contents of accumulator and add result to accumulator
R k Shift accumulator right (see below)
L k Shift accumulator left (see below)
E n If accumulator is positive or zero, jump to location n
G n If accumulator is negative, jump to location n
I n Read a character from paper tape into the least significant 5 bits of location n
O n Print character in the most significant 5 bits of C(n)
X No operation
Y Round the accumulator to 34 bits
Z Halt
I/O Devices
The following devices were attached to the EDSAC for input and output.
To read input from the telephone dial, the machine was halted with a Z
instruction. Dialling a digit caused it to be added to the accumulator
and the machine restarted.
A bank of uniselectors was used to load the "Initial Orders" (boostrap in today's terminology) into main menory.
There were also some cathode ray tubes capable of displaying register
values and the contents of parts of the main memory. These were mainly
for diagnostics, but the memory display could be used as a simple form of bitmap output.
Operator Controls
Clear Button Clears all registers and main memory locations
Start Button Loads the Initial Orders into memory and begins executing them
Stop Button Manually stops execution
Reset Button Continues execution from where stopped
References
EDSAC Simulator for Windows - includes documentation providing more architectural details.
The Preparation of Programs for an Electronic Digital Computer - lots of very detailed information about a later version of the machine.
The EDSAC Wikipedia article lists many other useful references.
