I added tests to the combined test suite for the Input instruction and the telephone dial input facility.
So that dial input could be tested automatically, I added a trigger circuit that watches the teletype output looking for the sequence of characters D#n, where n is a digit, and dials that digit.
Changes to main circuit
Dial test trigger subcircuit
Changes to dial simulator subcircuit
Additions to test program for input testing
# # INPUT instruction # Enter with AC = 0 # Exit with AC = 0 # Expected output: INP # I_test: O cI F I temp F A temp F L ^12 T temp F O temp F I temp F A temp F L ^12 T temp F O temp F O sp F # # Dial Input test # Enter with AC = 0 # Exit with AC = 0 # Expected output: D#5P # dial_test: O cD F O figs F O chash F O c5 F Z F O lets F A temp F S k_5 F F fail D O cP F O sp F
