TECHNICAL PARAMETERS
- Perfect quality enclosure (colour: black, red, blue), laser-cut and engraved
- Enclosure dimensions: 1.3 x 2.75 x 4.8 inch (33 x 70 x 122 mm)
- 16 tube sockets compatible
- Power on/off switch
- Power on LED indicator
- Voltage adjustment: 140-200V
- Frequency adjustment: 1-10Hz
- Voltage measurement output
- Auto control
- External power supply: 12V; 1A DC; plug diameter 2.5 x 5.5 mm; center pin positive+
PERFECT QUALITY COMPONENTS
EXCHANGEABLE TUBE SOCKETS
- 16 sockets available for dozen different tubes and nixie drivers
- Each socket have same form-factor
- Acrylic enclosures
- Easy to assemble and use
- Dedicated carton packaging
You can find this project and support on the Indiegogo Crowdfunding Campaign: https://igg.me/at/universal-nixie-tester
Marcin Saj
Denys Kardash
Steve Hernandez
