Sketch the Head lamp
Before we make a actual head lamp first we will make sketch then make a real as it.
Updated heat sink
This is almost the same headlamp like previous but having updated heat sinks light weight and having lags. Actually a heat sink having more legs give better results. In previous head lamp we used aluminum blocks of heat sink. Hard wire length 43 cm heat sink squire size
40.5mm we need. Strips size are respectively 22,1 cm and 32,2 cm
