For making body heat powered lamp first we need 4 aluminum blocks for heat sink propos. In 4 aluminum blocks we make at least 2 wholes. Then We will connect 4 blocks with hard wire passing by all 4 blocks wholes. First and last side of hard wire will fix two strips with this our headlamp will easily be hold on our forehead.
Wasim Sahu
