We're making progress towards reading our 7 different accelerometers / IMU chips.
At the moment, we've wired up & are reading the I2C data from the following three chips:
- Kionix KX022
- Kionix KX112
- STMicroelectronics LIS3DSHTR
The ones we're still working on are:
- Kionix KX062
- STMicroelectronics LSM303AHTR
- STMicroelectronics LSM303CTR
And the 7th chip, an STMicroelectronics LIS3DHHTR, is out of stock with a 14 week lead time, so we're ruling that chip out before spending any more time on it.
Now for a walk-through of the pin layouts. The controllers are all Arduino Pro Mini boards, and the "IC"s are the respective Kionix and ST chips.
KX022
![](https://cdn.hackaday.io/images/8156021532315277141.png)
resistors are 1k Ohm
capacitor is 0.1 uF
KX112
![](https://cdn.hackaday.io/images/5035951532315316105.png)
resistors are 4.7k Ohm (1k is fine as well)
capacitor is 0.1 uF
LIS3DSHTR
![](https://cdn.hackaday.io/images/2854861532315345170.png)
resistors are 330 Ohm
capacitors are 0.1 uF and 10uF
