The parts for the prototype came about 3 days early from LCSC and EasyEDA!
I don't have a solder stencil yet, so I used my solder paste for the whole board. I must say I've gotten somewhat good at soldering .5mm pitch ICs, considering only two pins had a joint. Trick is so simple yet so true: less is more. Use a tiny bit of paste and it works!
On the flip side, my PCB has a pretty bad error in it: the SRAM pinout is completely wrong. When I plugged in the board the 3.3v regulator got hot and the SRAM chip started getting warm. I had to cut the ground connections to salvage the board.
Anyway, I finally connected the board to ISE iMPACT and it recognized the FPGA! So the board works. Time to start testing my compiler on real hardware!!
Dylan Brophy
